2002 F250 CCLB 4x4
03cody
Bethany Illinois
Price: 11,000 OBO
Miles: 259,000
Truck has had transmission gone through within the last 2,000 miles. The reason we had it redone was because the torque converter was slipping in overdrive. We had some stronger clutches put into it and a new torque converter. Also, it has new wheel bearings, axle seals, and dust seals up front. May need ball joints soon as I noticed the tires are starting to cup just a little. The tires on it are pretty good, I think they have around 25,000 miles on them. Truck also recently got a new water pump, new ac pump, new 4x4 vacuum pump, and new injector cups. We did all this to make sure that it was going to be good to go for horseshow season but then we found a bit newer truck that we couldn't pass up. That is the only reason we are selling this one. It does have some rust over the fender wells on the bed.
The miles will not go up much because it is no longer a daily driver. Truck has always been maintained well and was only used for a grocery getter and to pull our two horse aluminum trailer. It is all stock, never been tuned or anything and we are the original owners of the truck.
If you have any questions, feel free to contact me on here or since I don't check as often as I should my phone number is 217-358-2814 (call or text whenever)
My name is cody
Thanks for looking!
03cody
Bethany Illinois
more pics
