zilla68
Posting for a friend, thought someone on here might like a nice truck with lots of goodies on it. Truck is located in california
2002 F250 Superduty with the 7.3l Powerstroke diesel, two tone green/blue and silver factory paint. crew cab, long bed, 4x4.
Truck has 140k miles on her, various upgrades all designed to aid in towing my 5th wheel to the desert. It has never been abused, raced or neglected and always maintained meticulously. The only reason im selling the truck is because I now tow with a 2008 F450. I'm asking $14,999 OBO.
Contact Nick (619)417-3405 or Jim (619)417-1642 (Dad)
Interior Accessories:
-A pillar gauges (EGT 1600*, 35psi Boost, Short sweep trans temp)
-Dash gauges (Full sweep trans temp in return cooler line, Electric fuel pressure, third is empty for whatever you want)
-Factory CD, Tape stereo
-Kenwood 5x7 door speakers
-Infinity 6x9 back speakers
-Captians chairs with center console/ middle seat
Engine modifications:
-AEM 4" intake with dry flow filter
-4" down pipe back exhaust with 6" chrome grand rock stacks in the bed.
-Adrenaline High pressure oil pump from dieselsite.com
-Coolant filtration system from dieselsite.com
-Swamps Stage 2 split-shot injectors (Swamps-S/175/30)
-Brand new dieselrx glow plugs and glow plug relay
-Brand new Garrett ball bearing turbo charger gtp38r
-Ported and polished intake Y manifold (aih delete)
-powder coated hot side intercooler pipe ( candy blue)
-stainless steel bellowed turbo up-pipes from dieselinnovations.com
-regulated return fuel system running 65psi also dieselinnovations.com
-BD diesel heavy duty intake boots and clamps
-DP-Tuner chip with an in dash switch on the fly. 4 custom tunes designed specifically for my setup on this truck (stock, 15klbs tow, 120hp race, 140hp aggressive)
Transmission:
-bullet proof BTS (Brian's Truck Shop) Trans with approximately 40k miles on it
-6.0l trans cooler
-Aux 16" fan on the coolers
-Synthetic Ams Oil atf fluid changed at 25k miles on the trans.
-4wd is shift on the fly with optional manual locking hubs
Chassis:
-4 Brand new 285/75/16 Cooper Discovery AT3 tires
-Centramatic wheel balancers at all 4 corners
-2" shackle leveling lift
-Cross drilled and slotted front brake rotors
-EBC yellow stuff brake pads up front
-Brand new Pro Comp steering stabilizer
-Bilstein shocks all around, fronts are new
-Mag Hytec rear diff cover
-Factory 3.73 gears & limited slip
Towing Accessories:
-20k lbs. 5th wheel hitch comes with truck
-Brake controller in the cab
-Load leveling air bags with in cab adjustability while driving down the road.
I will post when it sells
Transmission:
-6.0l trans cooler
Chassis:
Towing Accessories:
