2002 F350 CCSB - 5.9L Cummins Twin Turbo - Sleeper Grandpa Truck
Layson
2002 F350 Crew Cab Lariat Short Bed 4x4 with Tow and Camper Package.
This is a very clean well built truck that has 205,000 miles on it. The motor has been swapped with a 2004 5.9L and has 25,000 mile on the rebuild. The truck is clean but the outside has the normal wear and tear. All the gauges work except for the Fuel Supply Pressure on the CTS.
This is a sleeper Grandpa truck.... The combo should be in the 800 horsepower range and he does have (2) dyno sheets of 802 and 820.
Suspension
- 2006 Front Axle with Coil Spring Front Suspension, 06 steering box, new rotors, calipers, master cylinder
- ARG power steering pump
- Traction bars
- Detroit Tru-trac rear diff
Engine/Trans
- 2004 5.9L Common Rail Cummins Motor, 25K on rebuild.
- ARP head studs,
- Industrial injection 85% over Dragon fire CP3
- 150HP nozzles on stock body injectors
- Engineered Diesel custom compound Borg Warner turbo's, polished housings, billet compressor wheels, 63mm top turbo over S478 bottom turbo
- Hamilton 110lb valve springs
- Destroked Billet Flex Plate, Trans Adapter, Electronic Tach. Adapter and Throttle Adapter
- PCS Transmission Controller
- BTS 4r100 Transmission with new TC and new V10 Cooler
- Smarty Programmer with UDC
- Edge CTS Monitor with back up camera, EGT, tranny, boost and fuel pressure sensors
- Banks 6.0 IC
- New radiator
- Air Dog 165 fuel system with new 4G pump
- Painless wiring kit
- 2008 Rear Tailgate
You can either message me if you have any questions and I will do my best to get you answers.
Or Call Gordon whom is the owner of the truck at (503) 956-7394
Located in Clackamas Oregon
$29,000 OBO
Strokersace
Towanda, KS
Had no idea that Gordon got Greg's truck.
It needs a chrome rims back though. Good luck with the sale!
