2002 Volkswagon Jetta GLS TDI
45+ MPG Diesel
170k Miles*
Automatic
Leather*
Heated Seats
Power/heated Mirrors
Sunroof
Cruise Control
Tilt Wheel
Alpine head unit with Aux and USB
Factory Upgraded Stereo with Amp
Extremely Clean for years and Miles No Rust*
New Rotors and Pads on all 4 corners less than 500 miles ago
8year Warranty Battery installed last August
Cars was purchased not running due to jumping time.*
Recently has been gone through and is ready to go.*
All of the following parts have less than 150 miles on them.*
For those wondering also jumped time while cranking and no rods were bent.
This was verified by checking each pistons TDC to measure for the headgasket and all were within .001-.003 thousandths.
-Timing Belt
-Serp belt
-Tensioner
-Camseal
-Large roller
-Small top roller
-Small roller bottom
- Metal blade Waterpump
-VW Longlife G12 Coolant
-Large roller bolt
-Engine bracket bolt long*
-Engine mount to body bolt
- Engine bracket bolt
-Engine bracket bolt short
-Injection pump bolts
-Vibration dampener bolts
-Vacuum Pump Seal*038 145 345
-EGR seal*
-Intake Manifold gasket
-Serpentine Belt Tensioner
-Crankshaft Bolt and Seal
-tensioner and roller studs
-Pump sprocket bolts
-harmonic balancer bolts
-Cam Shaft
-Cam Lifters*
-Head Studs
-Head gasket
-Intake and Exhaust Valves
-Intake Manifold Gasket
-Exhaust Manifold Gasket
-Turbo return gasket
-Injector seals
-Fuel Lines
-Vacuum Lines
-Trans pan Gasket and Washers
-Trans Filter
-Fuel Filter
-Transmission was also flushed and new fluid added
And Im sure im forgetting a few things but do have all receipts for work done.*
CONs
-few scrapes on front bumper,
-one or two dings on passenger side door
-ding on roof
-CEL due to EGR valve being disabled to help keep intake manifold clean( can be taken care of with a flash or tune) Also could hook back if wanted.*
$6,000 OBO
