2003 6.0 rough and high idle
hjen27
Alabama
I've had my 03 f350 for a little over a year now. When I first got the truck it ran well but after a few months my hpop went out. I have since replaced the hpop, the icp, the ipr, the PCM wiring harness and the PCM its self. But the truck continues to idle at 970 rpms. I kept getting codes for the icp signal being high and low so I replaced the icp again. The truck continues to idle high and surge I'm at a loss at what to try next. Has anyone had this problem?
ncollins64
winchester springs, tn
Just an idea, but I had similar issues before on a truck, I checked my ebp sensor and the pigtail connection was ripped and had broken wires. Replaced the pigtail and all problems went away.
hjen27
Alabama
What year model was your truck?
Mesa, AZ
Is it kinda fuel knocky and real rough? Check your eot sensor. I’ve had quite a few that had broken lock tabs on them, and while I was doing a turbo or something it comes unplugged and runs terrible.
hjen27
Alabama
When it idles up the hpop pressure defaults to 850.
DEEZUZ
NO PUKESTERS
NWI
So your running to default. Check the 5v at the sensor pigtail, wiggle test, etc.. The circuit sounds funky. Icp sensors get icp pigtails when changed.
hjen27
Alabama
I replaced the pigtail the first time I checked and found it was bad. But I will definitely check it again and make sure.
hjen27
Alabama
Mesa, AZ
These are the codes I'm getting
The p0046 is for the vgt actuator, the 67x codes are glow plugs. Seems like there’s a lot of shit going on here. Check the harness where it runs under the turbo. Could be chafed there and have broken wires. Your first post said you replaced the harness, correct? Did you replace it with a new harness, or a used one? Are you sure when you replaced the icp all the wires went to the correct pins? I’ve done that a couple times when I’ve been in a hurry and didn’t pay real close attention to the colors when I was splicing it. Also, where did you get the icp from? Is it a ford part?
hjen27
Alabama
I replaced the ipr and now the truck runs great.
DEEZUZ
NO PUKESTERS
NWI
Was the screen compromised or heavy debris on it?
If so, if you don't change the screen under oil cooler you'll be back at the IPR soon.
DEEZUZ
NO PUKESTERS
NWI
Electronically they fail very rarely. Make sure it has the heat guard around it and that the y pipe has the heat shield.
