nickg9785
ok guys so at work we have a 2003 7.3 e350. it came in and wouldn't start, the guy said it ran away. and it was pushing straight fuel out of the left bank up pipe. so I yanked the motor and found a burnt up piston. so stripped the whole motor down and the cam was pretty well wore out. so it got one piston all new rings and standard bearings. heads decked and a full valve job since the valve faces were worn pretty thin. along with a new cam and lifters from ford. also got 8 new injectors for it. got it back together and fired up and it has a code p1263 for #3 injector high to low side short, it has a new uvch and I checked the wiring harness while I had the motor out. when it runs it seems real clattery compared to how they normally sound. and seems to lack power and blueish smoke out of the tail pipe. while your driving the clatter will get loud then go away then comeback again almost like its cutting a injector out. also when it sits over night or even for an hour it takes a lot of cranking to get it to fire. is there a way for me to check if the hpop is draining back? and ideas would be appreciated. thanks guys!
