It's intermittent. Won't do it all day, then the next day it will start again. Throttle pedal?
Apr 9, 2014 #1 isootmypants New member Joined May 29, 2011 Messages 646 Reaction score 0 Location North Jersey It's intermittent. Won't do it all day, then the next day it will start again. Throttle pedal?
Apr 9, 2014 #2 Irontx New member Joined May 18, 2011 Messages 843 Reaction score 0 Location Texas Could be low ICP also.....
Apr 9, 2014 #3 mustube New member Joined Mar 16, 2013 Messages 610 Reaction score 0 Location Austin, Tx You can check your throttle pedal and icp with a bluetooth adapter and the torque pro app. You can set up gauges for both and see which is causing it.
Apr 12, 2014 #4 Gary Member Joined May 21, 2011 Messages 409 Reaction score 1 Location South Lyon Mi I don't think it's your pedal, probably more like a boost issue which could be caused by the MAP or EBP, also check fuel pressure.
Apr 13, 2014 #5 isootmypants New member Joined May 29, 2011 Messages 646 Reaction score 0 Location North Jersey Welp, the truck wouldn't start again after it was driven. I'm leaning towards ipr valve.
Apr 16, 2014 #6 isootmypants New member Joined May 29, 2011 Messages 646 Reaction score 0 Location North Jersey 'twas the ipr. All good now
Apr 17, 2014 #7 Irontx New member Joined May 18, 2011 Messages 843 Reaction score 0 Location Texas isootmypants said: 'twas the ipr. All good now Click to expand... Glad ya got it figured out..
