mind if I smoke
I have a 2004 F250 6.0. It has 170K on it. About 10K ago we pulled the cab for the second time. We put on new Ford OEM heads, Adrenalin HPOP, new DD clutch, and allot of other things. Spent a ton of money. About the only thing I didn't do was injectors. Now the injectors need to be done. Two weeks ago I bought my first home so I currently do not have the money for a new set. The truck will start and run but it runs rough and it sometime will not fire back up when it's hot. I have no idea what it is worth so I'm trusting your guys opinions. This is a great truck with allot of work put into it. Little about it, 225/100 injectors, 68mm CK turbo, full fuel system, full oil system, full air system. It does have rust in the bed but the rest of the truck is very solid. Feel free to text/ call me or hit me up on here, 865-254-6283. I'm located in Vonore, Tn outside of Maryville. I need to move this truck so I can get something else without getting totally screwed.
