topgun
- Joined
- Oct 10, 2012
- Messages
- 32
- Reaction score
- 0
Ok I need a lot of help here please. I have a 2004 that will not even crank over. I had this problem before i did the EGR delete while doing so i installed a new HPOP, and ICP sensor in hopes it was one of them. I also had the starter checked at Advanced and it spun with no problem. The engine is not locked up I know because i jumped the starter and the engine spun just wouldn't fire. I also have two new batteries in it as well. All gauges light up and i believe the injectors are working i just cant hear them over a vacuum pump or something making a noise like it did before all of this started. Also i don't believe my fuel pump is working since i can not heat or feel it and my filter housing is not filling up. I have checked all fuses, that I know of visually and with a voltmeter even the 10 amp for the ficm which is also new. Any Ideas??????
