2005 CCSB fuel tank question
Smokin 6.0
Indiana
I have a 2004 CCSB that I believe the fuel level sensor is taken a **** on. It gets below a half tank and will go up and down. It went back up to a half tank the other day and I ran out. I think I’m gunna have to pull the tank and replace. My question is has anyone ever put a 38 gallon tank in a shirt bed ? Is there room ? Figured if I have to pull the tank might as well put a bigger one in if I can.
bismic
You don't have to pull the tank. You can raise the bed.
Remove the bed bolts up by the cab. Just loosen the ones near the tailgate. You may need an impact to get the bolts lose, but if you have one, the job is easier this way.
After that, you can tilt the bed up w/ a jack. Support it w/ 2x4's before you get under it. That will give you enough room to remove the tank sending unit lid.
It won't fit. Get a titan replacement if you want a bigger tank.
