2008 6.4 Noise
powersmokin64
Johnson City, Tennessee
Tell me about it. I sent the dimensions and quoted them 41 lbs and they rebilled me and said that with the measurements it should weigh 300lbs. lol haven't been in the gym in a while but I am quite proud I was throwing that "300 lb" exhaust around pretty well
Desertdweller
29 Palms CA
OK so my livewire is fine it just had a button that was stuck. The HPFP is fine just had air in the system. Now for the high pitched noise, I found the elbow that connects the turbos together loose because of missing nuts and a broken stud- the one that goes through the valve cover and into the head, I kinda wiggled it back into place and the noise went away so I will update after I do the repair. Thanks for the help everyone.
The repair went great. The broken stud came out no problem, I replaced the broken stud and 4 missing nuts and the truck is running perfect.
