2008 v10 5r110 same as 6.4 trans
2wd-fire
I know the stall is little higher but is everything else the same. Thank you Ryan
Sent from my iPhone using Ta
2wd-fire
The intermediate one way clutch is different. The V10 one is actually the better one! Either one will work just fine.
Ford only made one 5R110 case. They are not different cases.
Thank you mark I was hoping you chime in. Do you happen to know how much higher the stall is I couldn't find any definitive info
Lipka101
Maryland
The stall is in the torque converter. The v10 converter is probably different than the 6.4.
