2011-2013+ OEM Fender Flares (FX4/Gray Style) $200
Bikeluver43
I have a set of Factory Fender Flares, Charcoal Grey off of a 2011 F350. I bought these hoping they would fit my 02 but the fronts are too long. I could cut them to make them work but would rather just get something that is meant to fit.
3 are in mint condition - no scratches/scuffs or anything. The right rear has a small crack on the very bottom that wouldn't be noticed unless you are on the ground looking up. I can have this glued by a body shop I work with if the buyer prefers, but I'd rather be honest about it up front. Other than that, there is no scuffs/scratches on that flare as well.
Pics below, looking for $200 + shipping (actual shipping). These may also fit the 08-10's but I'm not 100% sure.
**Those are water spots on the flares, it was raining prior to the pictures**
TXGLASSMAN
Keller Texas
how hard would it be to fix that crack in that one? i need a set to re paint and then go have wrapped to protect them
Bikeluver43
A body shop could repair so you'd never see it. Personally I'd get some epoxy glue, lightly sand, high build primer, then paint. Thats basically all they would do anyways.
Bikeluver43
Guy had already removed them from his truck but this truck is identical to his.
Truck is SixPointSeven's truck (member of Ford-truck . com) just using to show reference.
Bikeluver43
Sorry I have an 02 and the 08+'s won't fit my truck (reason for selling these ones). I'd consider other trades though.
