2mcclr
- Joined
- Aug 1, 2012
- Messages
- 92
- Reaction score
- 0
Hey guys, I've got a '12 with factory nav and the stock sub and amp. When I bough the truck the previous owner left a Rockford Fosgate Prime R250-1D amp and all the wiring in place. I bought a Rockford Fosgate P3S-1x10 pre-loaded sub and box simply because the box fit well under the back seat. Simplicity is key here. Now that it's all hooked up, the sub is a little muffled and lacks the low "punch" that I was hoping to get. It's still an improvement over the factory sub which I found to be pretty well useless but it still leaves a little bit to be desired. Is there some other component I can add to the system to make it hit a little harder it is it just the amp/sub combo that's the limiting factor? Any help is appreciated! Thanks!!
