2015 6.7 DPF Regen Design
Sarge03
Hey guys, can anyone tell me how the 2015 conduct the Regen cycle? Does it dump fuel on the exhaust stroke or does it have a bypass system using an injector by the DPF like the Duramax?
Sarge03
Well I think I found the answer but now I have more questions.... If the regen cycle is completed by fuel being dumped into the cylinders on the exhaust stroke, couldn't there be a concern for fuel contamination in your crank?
78f100
Bonifay FL
Yes, I am not sure what if any changed for 15 but in the 6.7 class I went to they said it used all 4 cylinders opposite of the egr to regen. Where the 6.4 only used 2 cylinders it uses 4 and I would assume smaller amounts of fuel per cylinder would help keep contamination at minimum.
Sarge03
Gotcha. Thanks for the input. Completly new to diesel and trying to learn all I can about how my new engine works.
Stangr8cr
I've done oil samples of mine deleted and emissions intact and fuel in oil has always been .5%.
Keith
