2015 f350 weird front end noise
carcare
Tighten trac bar bolt to frame by lf wheel. Or have someone rock wheel while u watch m listen. Just snugged mine yesterday. Common problem in fords for years. Give it a shot. It's free and takes a couple mins
the plumb
WI
Just had my '15 in dealer. Greased intermediate steering shaft. Much better. Ordered new part. Will let you know if it works.
RuralCRNA
My 2013 does the same thing. I called Ford and opened a tag on it. Hopefully when I take it in (again) they won't be able to fix it and will have to evetnually call in an engineer. I beleive it has to do with the ABS as well. I can feel it in my brake pedal. It always happens on left-hand turns when there is a deviation in the grade of the road (like a dip).
