2015+ turbo & piping kit dyno numbers?
NCSU dirt man
Ft. Bragg, NC
hit me up when you're ready, i'll make you a deal you cant refuse !
hey mike, one question that popped up in my head is will it be difficult to retain my SOTF switch functionality through my SCT X4 tuner with either a streetmax or 15+ turbo swap even though my truck is an '11 F350 SRW?
bigrpowr
<How I Fly
Administrator
nope,you good !
doo dah
San Antonio
I've got a 12 with stock pump and 63mm non vgt II kit. 600 is the goal so I would need more than just a 2105 pump upgrade? I'm shelling out several grand right now rebuilding the trans (all Suncoast 750hp internals, billet FP, and convertor) and can't do another 3 grand for dual pumps. I know modded pumps are out there but they approach the cost of a dual kit so I was looking at a factory 15 or 16 pump hoping to get 600. My CP4 has 210k miles on it so I would like to replace to avoid the increasing threat of it sh*t canning my entire fuel system.
Jomax
Arizona
You'll be knocking on the door of 600hp. But to have exactly 600rwhp or more would require a stroked pump or duel pump.
I've never heard of a 6.7 break 600hp with a stock 15 pump, other then fake dyno numbers and no time slip to back it up.
doo dah
San Antonio
Close is good enough. I don't think the 63mm will support more than 600 anyway so 575-600 would be fine. I'm replacing not just for more HP but also seems like a good time to get in front of the potential of failure based on the amount of miles I have and fact I'll keep this truck beyond 400k miles. I appreciate y'alls input!
Jomax
Arizona
I put down 580 with track times to back me up. You'll be happy!
doo dah
San Antonio
Sweet! They will replace it while the transmission is out. I'll have them dyno and share the results in this post, probably be a couple weeks.
how come you didnt go with a midwest diesel and auto trans?
I did 537hp last weekend with air filter still on and blowing a coolant fitting. No track times yet, maybe Sunday.
what air filter are you running?
doo dah
San Antonio
I am having a local diesel shop do the work for me. They got all the parts from Suncoast and a trans shop will assemble everything so it will be warrantied. I won't have to deal with cores or shipping a transmission twice plus I want to give these local kids my business. Nothing at all against Midwest.
08Monster
I thought about doing this as well. Let me know how it holds up.
Sent from my Moto Z (2) using Tapatalk
doo dah
San Antonio
So TCM seems to be jacked. I must have one of those 11-12 that do not like to be tuned. Makes sense since I had no issues until I changed from Torque Tech to the SCT and since then have probably had 10 tunes loaded with no improvement. They got base file from the Ford dealer and a buddy of mine wiped the TCM clean then loaded the file and it is still jacked up. I haven't had my truck for over 3 weeks now. Hopefully the truck runs great when they finally get it figured out otherwise I'm getting rid of it.
why not just put it back to the way it was till they figure it out?
