same turbo as 15.
Ok so it is in Fact a conventional VGT? I kept reading that they went back to an SST and the intake plenum blocks the view too much to tell for sure by looking. What other changes are there? HPFP different?
I wonder how long it will take Ford to switch to the Denso Commonrail system with solenoid injectors as GM did.
Charger is the still a conventional VGT.
HPFP is the same, as are injectors
Incorrect, 2017 Powerstroke have switched back to a SST turbo, that is larger than the 11-14 models, to help prevent the overspinning issues the 11-14 had.
LOL ^^^^ Bullchit.
Who dafuq are you?
Someone, who recently purchased one...
Check out ford website under specifications, if you have trouble believing me.
http://www.ford.com/trucks/super-duty/2017/models/f250-xl/
It does say sst under the engine specs.Let me know what you find when you pull your turbo apart....many of us that have commented on this thread have done just that. These turbos are a standard VGT.
Or even better, pop your hood and tell me where the second air inlet path is that feeds the second stage of the compressor wheel.
On edit: I looked thru the link you provided but I must be blind-i can't see any reference to an sst turbo. Maybe because I am opening on a mobile device?
Found it now....still don't understand why they call it that.
Does anyone have any specs on the 2017 turbo? I believe it is bigger than 15-16 due to fact that max torque kicks in at 1800 RPM instead of 1600. like 11-16.
