2019 F450 Integrated Brake Controller Install
PsRumors
Cartersville, GA
We ordered a couple 19 450s and chose the tow package which for some reason does not include the integrated brake controller.
What will be required to install and get up and working? We do not want aftermarket
jcain
The controller itself and turning it on via forscan yourself or having a dealer activate it.
Matt
Minnesota
Check in your fuse box under the hood to make sure you can put a fuse in the needed location. On some of the 18 F150s you have to run a jumper wire for power. Not sure if Super Dutys had the same issue.
PsRumors
Cartersville, GA
Worked like a charm....first time I've used Forscan but very easy
All wiring and fuse was in place. Took maybe 10 minutes to install and program
