22" wheels and 35" tires pics only
kevin1106
La Plata MD
Here's mine
Just finished giving it a bath..
Icon 4.5 lift stage 1, American force 22x10 25mm offset, NITTO trail grapplers 325/50/22
Slight rub at full lock on drivers side. 10 min trim job on bumper bracket, very minor.
Not happy the front sits higher than the back. Waiting on my ouo 7in traction block also this will center the rear wheels in the fender well again.
Breaking Habits
Mapleton, Illinois
Truck looks good
You will love the traction blocks. Money well spent! Once you get it done you should look into the Adjustable Link Arms in the front. Drastically helps the front end perform and drive properly, and you can recent the front axle as well!
GreyArea
MIAMI,FL
2.5 level, bilstein shocks, steering stabilizer, 3 inch block in the rear , minor trimming, 22x12 gear big blocks, 35x12.5x22
Whitebuffalo
Hey unbroken, would you possibly have any pictures of how far the tire sticks out? I was thinking stock fender flares but wasn't sure if they gave any more coverage for that kind of offset. Thanks!
UNBROKEN
They still stick out probably 1.5". The factory flare covered a little over an inch if I had to guess. I never actually measured it.
DarcyB
Airdrie, Alberta, Canada
Gonna try and revive this old thread. Anybody have anymore pics with their 22" wheels and 35" tires. Looking at a similar setup in the summer. Thanks!!
Sent from my SGH-I337M using Tapatalk
HPGod
285 55 22's. (34.3x11.7)
HPGod
Nice, I take it That's on 4.5" lift?
Just 2.5" front, 2.0" rear. Fairly certain I could have run these without any lift also.
This is with the lowest offset outer option on these wheels. The rears stick out aprx .5" and have just enough clearance between the duals.
