I'm still with a stock turbo and If I just plant the pedal from a stop I never see over 23-25 psi. If I am cruising already and lean into it good I'll reach 28-29psi, only other time is when I have a big brick on wheels behind me. Then I'll push a squeak more than 30. (read from my glow shift 3in1 gauge).
I think when the engine is at WOT there is so much air moving that the charger can't keep up. We can make 30 psi when we plant the pedal at cruise, because the turbo spools up so fast and the engine can't gulp it down fast enough, then when you get to the top end you can't hold 30 psi anymore because the engine is wound up and moving that much more air.
I am just thinking out loud here, maybe someone can back that up...
