Cory S
hey guys i have a 2000 stg 2 inj 160/80;s and a 38 r and on tunes from a few different ppl i can only get 24 plbs. MAX stock truck wth a chip can keep up with me? any help
Just to clarify a couple things. 160cc is a stage I injector. A 38r will read less boost than a stock turbo for the same amount of power because it flows better.
Is the wastegate actuator still connected? Take the red boost line off the little canister and plug the red line.
What kind of truck is the "stocker" with a chip. Same truck/body style/weight/tire size? How many miles on your motor? Have you done a compression check? How did you check for boost leaks? Have you checked the exhaust and up pipes for signs of leaks? Where and from who did you get the injectors and turbo? Have you done a scan/buzz test/contribution test?
Could it be the HPOP not keeping up Cory?
Hows ICP
