sunrisefordparts
- Joined
- Jun 14, 2011
- Messages
- 5,453
- Reaction score
- 7
Next paycheck
Sent from my SPH-L710 using Tapatalk
roger that
Next paycheck
I believe this what I will need to do a cab head gasket job on my 08 6.4, 8EA47463 is the VIN#. A quote shipped to 54904 would be appreciated. Will order this week.
If I missed anything, add it to the list. better to have extra than not enough.
qty part number
1 8C3Z-6079-D valve grind gasket kit
6 W712878-S439 Body Bolt(CREW CAB ONLY)
2 W712879-S439 Body Bolt(CREW CAB ONLY)
1 8C3Z-9T514-C Turbocharger Seal Kit
1 7C3Z-6L612-B Turbo Outlet Gasket
2 8C3Z-6N640-A Exhaust Gasket
2 8C3Z-6N640-B Exhaust Gasket
4 W302870B Fuel Line Washers
5 1817957-C1 Exhaust Pipe Bolts
6 W302494 Exhaust Pipe Nuts
2 W300003 EGR-OC Bracket Bolts
1 W711484S439 Intermediate steering shaft bolt
2 388898.S Nylon Washers (Hydro Boost Lines)
3 W302674 Push Nuts (glow plug module heat shield)
heres your quote, i added exhaust manifold gaskets as they dont come in the valve grind kit and took off turbo seal kit which comes in the valve grind kit. everything else seems pretty cut and dry
Deal, what is the correct way to pay. Paypal and put the quote number and contact in the info box? Screw it I will just call.
placed order, thanks
thanks for answering your own questions :thumbup: thanks for the order bud.
If only people would hear half of my conversations with my voices! They said everything should out tomorrow, could you shoot me a tracking whenever they get it out.
Thank you:blitzed:
Thank you:blitzed:
could I have a price for a harley davidson grille for a 2010 f350 in primer so it can be painted shipped to 06043. Thanks!
How much for oil and fuel filter kit for 2006 6.0L
I am needing ford head gaskets for a 05 6.0 Powerstroke. How much?
Thanks. Are those the racor filters?
Just saw on your signature about ordering
can I use my quote# to order online some how. I only see being able to order by part numbers.
