25% discount on ford parts to members
sunrisefordparts
2006 f250. Need a price on injectors and head gaskets.
injs list $264.29 each sell $212.75 w/exchange (core $180)
head gaskets list $197.94 each sell $154.39 (just need to know if the truck is 18mm or 20 mm heads)
shipping $20 for the set of 8 injs.
q#399454
sunrisefordparts
sunrisefordparts
Pricing on these items for a 2006 f350 6.0L
HPOP
IPR Valve
STC Fitting
Stand pipes/Dummy plugs x2
Turbo gasket install kit
HPOP list $804.50 sell $675.78 w/exchange (core $150)
IPR Valve list $278.32 sell $200.39
STC Fitting list $65.03 sell $46.82
Stand pipes/Dummy plugs x2 list $162.13 sell $116.74
Turbo gasket install kit list $13.02 sell $9.37
shipping $20
q#401933
Matt_P
Lima, OH
These are all things Im needing for an 06 6.0
2- 18mm head gaskets
oil cooler rebuild kit
Intake manifold gaskets
exhaust manifold gaskets
upper oil pan gasket
lower oil pan gasket
rear cover gasket
rear main seal
HPOP cover gasket
Updated STC fitting with Hpop o rings and IPR rebuild
8- standard sized rod bearings
standard sized main bearings
bed plate gaskets
2- dummy plugs
Oil pan
Matt_P
Lima, OH
rear cover gasket
rear main seal
HPOP cover gasket
bed plate gaskets
2- dummy plugs
Oil pan
I also need 16 lifters
CT9AIX
MA
Could I get a price on the items below shipped to 02726. Thanks guys!
2: 5c3z-5310-fa (4800lb springs)
2: of the bolt that holds down the spring seat to the front axle on a 2008 f350 4x4. I threw away the stock bolts like an idiot when I put my leveling kit in
sunrisefordparts
4800 lbs spring list $137.78 each sell $99.20 each
spring plate list $43.17 each sell $31.08 (bolt only sold with plate)
q#402231
Stokes
First off, thanks for the awesome service on the X-code springs I ordered from you guys some while back!
I am in need of the Upper steering column cover for a manual trans truck. I believe the part number might be F29A-3530-EAW
thanks in advance for the help!
