25% discount on ford parts to members
sunrisefordparts
sorry, this is what i was looking for
Not in the catalog yet, but I was able to access the BOM for that vin....
looks like the headlamps will list for $1785.71, your cost will be $1100.00 each + $80 core charge and shipping. Not sure about availability yet....
Dzchey21
wyoming
well that is a start for sure. I guess when you have some idea on availabilty let me know. I will not be turning in any cores LOL
BigT
Utah
Looking for paintable mirror caps for the 08-16 style mirrors. I believe it’s PN: 7C3Z-17D742-A
Need both sides.
sunrisefordparts
Need both sides.
passenger side: List $110.93 -- your cost $68.33
driver side: List $115.45 -- your cost $71.12
+shipping
q594630
thanks,
Sean
fords4life
Greeley, CO
Can I get a price for front unit bearing on a '13 Expedition Limited 4wd? Last 5 of VIN are 12004. Looks like there are two options, but I can't figure out the difference. I also need the plastic trim piece for the outside edge of the drivers seat. The panel has 4 switches in it.
Thanks!
sunrisefordparts
Thanks!
Hi,
can I get the last 8 digits of the vin please
thanks,
Sean
MossBack
UTAH
04/2004 Ford F-250 6.0 Powerstroke parts needed:
1.Ford oil cooler kit
2.Ipr & 1 Screen kit
3.Intake manifold seals, Turbo o-rings
4.Blue spring kit fuel
5.Stand pipes and dummy plugs, (8) injector o-ring kit
6.Head gaskets
sunrisefordparts
6.Head gaskets
Hi,
can I get the last 8 of the vin.... '04 had a prod date split....
thanks,
Sean
KidCrane
Buena Vista, Co
Please shoot me a price on:
1. Transfer case
2. Front driveshaft
3. Auto hubs L/R
4. Carrier bearing
Last 8 of the vin 7EB13071
Please and thank you.
sunrisefordparts
6.Head gaskets
1.Ford oil cooler kit: List $439.83 -- your cost $290.29
2.Ipr: List $314.65 -- your cost $190.37
* Screen kit: List $58.19 -- your cost $31.45
3.Intake manifold gaskets: List $15.39 ea - your cost $11.51 (x2)
* egr cooler / intake seal kit: List $119.95 -- your cost $87.33
* Turbo O-ring kit: List $13.28 -- your cost $9.17
4.Blue spring kit fuel: List $84.93 -- your cost $57.08
5.Stand pipes and dummy plug kit: List $165.38 -- your cost $111.14
*(8) injector o-ring kit: List $6.89 each -- your cost $4.55 (x8)
6.Head gaskets: List $201.89 each -- your cost $144.35 each will need dowel size 18mm or 20mm
+ shipping
q595251
thanks,
Sean
sunrisefordparts
1. Transfer case
2. Front driveshaft
3. Auto hubs L/R
4. Carrier bearing
1. Transfer case: List $1925.09 -- your cost $1376.44
2. Front driveshaft: List $355.25 -- your cost $254.00
3. Auto hubs L/R: List $667.78 each -- your cost $404.01 each
***hub locks: List $160.68 each-- your cost $107.78 each
4. Carrier bearing: List $123.45 -- your cost $82.96
+shipping
q595252
thanks,
Sean
KidCrane
Buena Vista, Co
I’m in a bind and I hope you can help. I need the part number for the two bolts and the slip clips that have the pressed in nut that the carrier bearing attaches to the truck with. Can’t seem to find any info on this. Last 8 of the vin 7EB13071. Please and thank you.
sunrisefordparts
Hi,
the bolts are part number: 391413-S100 (list $5.40, your cost $3.24 each)
the nuts are part number:W719280-S439 (list $4.50, your cost $2.70 each)
thanks,
Sean
sunrisefordparts
2014 f250 6.7
BC3Z-8A080-H
BC3Z-8C633-B
BC3Z-8B365-H
BC3Z-8075-H
BC3Z-8C472-B
They are hoses and coolant tank.
Thanks
BC3Z-8A080-H: List $380.97 -- your cost $251.44
BC3Z-8C633-B: List $53.05 -- your cost $33.56
BC3Z-8B365-H: List $6.00 -- your cost $3.60
BC3Z-8075-H: List $54.55 -- your cost $34.50
BC3Z-8C472-B: List $30.00 -- your cost $17.25
+ shipping
thanks,
Sean
q597649
