25% discount on ford parts to members
sunrisefordparts
The VIN for the 2016 is 1FT7W2B67GEC84928, I need the steering box and I think it takes 3 bolts to bolt it to the frame. 2016 bolts are bigger then 2010, everything else I have. Thanks
The vin is coming up as a 2wd gas rig...
your cost on the gear box is $366.51 + $225 core charge (retail $608.56)
the bolts are $13.43 each ($24.42 list)
+ shipping
Q633409
thanks,
Sean
kleake
Sapulpa, OK
2008 F250 with 6.4L with dual alternators
Need lower alternator. I assume it is the 200A primary. Also need a new belt.
sunrisefordparts
Hi,
Yep it is the 200A primary, List $460.15 -- your cost $277.12 + $75 core
the main belt is: List $ 67.07 -- your cost $42.42
the secondary belt is: List $73.62 -- your cost $46.56
+ shipping
I have emailed you the quote...
thanks,
Sean
Could I please get part numbers and price for a full containment kit for a 2011 6.7, as well as a 2015 6.7?
sunrisefordparts
Hi,
Are you looking for the fuel contamination kits? If so...
2011: EC3Z-9B246-C List $ 4205.00 -- your cost $3202.50 + $1500 core
2015 Pickup: FC3Z-9B246-F List $4893.33 -- your cost $3726.70 + $1500 core
2015 cab/chassis: FC3Z-9B246-G List $4349.86 - your cost $3318.94 + $1500 core
+ shipping
***please note all of these are currently on backorder with no real eta....
thanks,
Sean
C2tuck
North Texas
Just wanted to give a shout out to Sean and Sunrise Ford.
Recently ordered a part from them and was accidentally sent the wrong one. After emailing he sent out the correct part and advised me to keep the other one as well.
Haven’t experienced awesome customer service in waaaayyy too long.
Thanks again, I’m definitely be giving you all my business in the future.
sunrisefordparts
Hello,
Looking for a front timing & oil pump cover for a 2000 7.3l please.
timing cover: List $544.95 -- your cost $359.67
oil pump gear cover: List $202.50 -- your cost $133.65
gasket kit: List $121.89 -- your cost $87.15
+ shipping
thanks,
Sean
Q636065
C2tuck
North Texas
Morning Sean,
Need a price on the hard coolant line coming off the drives side turbo on my 15, the new fitting, along with anything else required to swap it out.
Also bed a belt and tensioner for same truck.
Thanks
sunrisefordparts
Morning Sean,
Thanks
Hi,
Can I get the last 8 digits of your vin again?
thanks,
Sean
sunrisefordparts
coolant line : List $39.97 - your cost $26.38 (on back order through at least 2/01/21
on the '15 & up there is no separate fitting, the line bolts to the turbo
tensioner: List $94.71 - your cost $57.30
belt: List $59.67 - your cost $36.10
+ shipping
thanks,
Sean
Q637100
Nicky STang
Good Morning Sean,
Wanted to get a price on Turbochargers for 2020 Ford Explorer ST part #'s:
L1MZ-6K682-A, L1MZ-6K682-B
Also not sure of the part #'s for both the exhaust manifold gasket, as well as the flange gaskets, but would be looking to order those as well.
TIA!!
-Nick
Sent from my SM-N986U using Tapatalk
sunrisefordparts
Good Morning Sean,
TIA!!
-Nick
L1MZ-6K682-A: List $966.42 -- your cost $584.68 + $250 core charge
L1MZ-6K682-B: List $963.63-- your cost $583.02 + $250 core charge
manifold gaskets L1MZ-9448-A: List $6.98 -- your cost $4.61 each
flange gaskets L1MZ-6L612-B: List $42.75 -- your cost $28.22 each (currently on back order through 2/15/21)
+ shipping
thanks,
Sean
Q637105
Nicky STang
+ shipping
thanks,
Sean
Q637105
Awesome, Thank you for the quick response!!
C2tuck
North Texas
+ shipping
thanks,
Sean
Q637100
Well unfortunately that won’t be quick enough and I’ll be back out of town.
I found the parts locally for not much more.
Can you get me a price on motorcraft orange 50/50 coolant? I guess 8 gallons..
Thanks
sunrisefordparts
Thanks
Ok. The orange has now been replaced by the new yellow coolant VC13DLG.. your cost $11.78 / gal + shipping
f
