02BigD
Upper pad for an 05 paint to match front bumper. (directly below the grille)
Upper and lower ball joints for a 2002 PSD 4x4
2 each
its the blue spring mod without the housing for a 2003 6.0
part number is ether
6E7Z9C165B
or
3c3z9c165aa
3c3z9c165aa is the updated kit list $45.00 sell $33.75
Parts Needed:
- E8TZ-4676-B, Pinion Seal
- 390313-S100, Rear Axle Pinion Nut
- F3TZ-4859-B, Pinion Deflector (Not Sure if this is needed)
- N811880-S100, Rear Dive Shaft Bolt x4
mainly whats needed to change out the axle pinion seal since it leaks.
also tan dome light assembly for the 2003 f350.
or the internals that has the prongs for the center bulb.
Could I get a quote with shipping to 80831 for a wire harness part # 5C3Z-14A303-AA.
Thanks!
Can i get a quote on 8C3Z-4033-A and bolts plus shipping to 46725?
All for a '97 7.3L Powerstroke motor...
Head Gaskets
UHVC Gaskets
Head Bolts
i finally opened my package today and found out its the incorrect part.
i needed this part
Code: 6E7Z9C165B
http://www.riffraffdiesel.com/mm5/m...uct_Code=6E7Z9C165B&Category_Code=F601-FS-FPR
but i received this part
whats the correct part number?
head gaskets list $106.15 each sell $79.61 each
v/c gaskets list $80.00 each sell $60.00 each
head bolts list $3.24 each sell $2.43 each x36
