38r 19 max psi of boost.
under pressure
For comparisons sake,
Ive been with out tunes for a week or so, stock turbo is about 18 psi max.
Now on my DD tune, it makes 26 lbs and dynoed 303 in this tune.
Added the WW2 and boost is over 30.
so stock tunes your at 18 psi and just by adding the ww your over 30? or is that only with your dd tune? the way i read that is you have been without tunes and now it makes over 30psi
under pressure
I ment it to be in order as the tunes are back in. So in this order of progression over the past couple weeks.
Stock turbo, stock tune 18 lbs
Installed DD tune made 26 lbs
DD tune and WW2 and its 30+ i have 30 psi gauge. (time for a 45 psi gauge)
7.3 Cowboy
Well I unhooked my wastegate hauled a load of cattle today and made 21 psi. For what it's worth
