38r question
HaysKSFirefighter
Valley Center, KS
whats recommended for fueling system?
For a 38r I would go with some 238s if you want them tuned down. Your real limitation is a PMR motor, same as mine. Anything over 400hp and you run the risk of windowing the block. A set of stage ones will get you there no problem, but if you're looking to have something that you can expand on down the road I would spend the extra $800 or so and get some 238/80s or 100s.
Also, a RR would be a good idea, plus in tank mods if you haven't done them yet, this will get air out of the lines and make your sticks much happier.
I'm quite fond of Irate's regulated return kit, his hard lines to the heads are purdy!
2stangs8689
Lockport, NY
I just installed Irate's full fuel system, VERY nice kit. The hard lines are very nice, and the Fuelab stuff seems to be very working well so far.
