4" lift, 35's, gears and egts?
strokin6L
Springville NY
I got a buddy who has an 05 6L which has a 4" lift, 35's and 3:73's. He's running 205/100's and a RCD 68mm vgt powermax. His egts get pretty hot and is concerned. He can hit nearly 1700* in less than an 1/8th mile..cruising at highway speed in 900-1000* depending on outside temp. He wants to know if changing gears will help with egts. I think that going to a 66mm sxe non vgt will help alot. I don't know much about gearing....so just wondering if changing the gearing will help with anything. Looking for any feedback from someone with a 4" lift and 35's. Thanks!
Profuzz
4:30 was the best upgrade dollar 4 dollar I had done on my 06 6.0
Sent from my SAMSUNG-SM-G870A using Tapatalk
Profuzz
Profuzz
Towing he
Towing heavy was the biggest difference, 65mph 2200 rpm egt 1000-1100 . DD on a race tune truck felt like it loss couple thousand # 's .Red light to red-light racing huge difference
Profuzz
The change in gear ratio will aid in getting the truck moving faster ,in turn should help w / spool up ? High egts air leak ?
scparrish
DFW Texas
I am going to swap gears with the same hope that I can lower egts. I would seriously doubt he will see improvement in egts going non vgt, ask me how I know.
strokin6L
Springville NY
Actually everyone I've talked to said egts would go down with a non vgt. Gotta remember...the exhaust side of the RCD 68 isn't modified like a KC or Barder!
strokin6L
Springville NY
Buddy text me and said he was thinking about 4:56 gears...I'm not a gear guy, but that seems a bit much for a 4" lift and 35's...you think?
strokin6L
Springville NY
Also, I'm assuming the pinion gears need to get changed also along with the ring gears? Or are just the 4:30 ring gears needed?
Profuzz
All gears ,locker , rebuild kits & synthetic gear oil ! And mag tech covers 😉
Downey
Lock Haven PA
i would say get rid of the 100% nozzles would make a huge difference in egts.
What is he using his truck for? DD? street/track? towing? towing heavy?
cRaZy8
I am on 35's, with 430's, Yukon rear locker, Yukon gears, Yukon master rebuild kits, Red Line fluids.
175/30's and an S362.
2.5" Bilstein lift coils, F350 rear blocks.
My EGT went way down with this setup, from the previous (MTW St2 VGT, stock sticks, IDP Y pipe).
I used to cruise around 900-950* on the highway.
I am now around 800-850*.
Idle EGT went from about 375-400* to around 325*.
My cruise RPM at 65-70 jumped about 250-300RPM.
Like Profuzz said, the truck feels so much lighter around town. Much snappier.
Spools the non VGT faster with these gears and sticks better than the stock sticks and VGT St2.
strokin6L
Springville NY
Thanks for the feedback. He decided to go with 4.30's
