Will the 4r100 tcase bolt to the zf6? sent while hittin' easy street on mud tires
Mar 8, 2013 #1 yotaneck13 New member Joined Jul 10, 2012 Messages 510 Reaction score 0 Will the 4r100 tcase bolt to the zf6? sent while hittin' easy street on mud tires
Mar 8, 2013 #2 C ClassicIDI Member Joined Jun 16, 2011 Messages 137 Reaction score 0 Location CO The input shaft of the tcase is different for a ZF6 vers the 4r100 but the bolt pattern is the same. bottom line is you either need to swap tcase input shafts or the entire tcase
Mar 8, 2013 #3 yotaneck13 New member Joined Jul 10, 2012 Messages 510 Reaction score 0 Are so i can pull the input from the manual shift case thats comming with my zf6. And put it in the electric shift case thats behind the 4r100 and order a electric shift manual harness and pcm? Then sell the other case as a 4r100 manual shift? sent while hittin' easy street on mud tires
Mar 9, 2013 #4 C ClassicIDI Member Joined Jun 16, 2011 Messages 137 Reaction score 0 Location CO yep you got it
Mar 9, 2013 #5 co04cobra Active member Joined May 21, 2011 Messages 3,003 Reaction score 10 Location WV What year truck?
Mar 9, 2013 #6 yotaneck13 New member Joined Jul 10, 2012 Messages 510 Reaction score 0 2000 sent while hittin' easy street on mud tires
Mar 9, 2013 #7 yotaneck13 New member Joined Jul 10, 2012 Messages 510 Reaction score 0 F350 cclb drw. Im going to have to take my shafts to work and change the legnth too right? sent while hittin' easy street on mud tires
Mar 9, 2013 #8 co04cobra Active member Joined May 21, 2011 Messages 3,003 Reaction score 10 Location WV I have a manual PCM and possibly the harness. PM if interested.
