The tow/haul button is still functional. Kicks the 4r outta overdrive
Thanks
I assume Brian wouldnt ship out a trans without a PI converter.
The 6.0L and 6.4L use the Ford modular engine bolt pattern. That's different than the old small block bolt pattern.You can use the modular motor 4r cases because the 6.4 and 6.0 use a SBF bolt pattern. The 7.3 uses a BBF bolt pattern
The 7.3L uses the 7.3L pattern. That's different than the big block Ford pattern.
A trans from a 6.0L should be a direct bolt up to a 6.4L.
I'm pretty sure the top two bolts don't matter.
The modular case is stronger then the 7.3 case and there are still the same number of bolts holding it to the 6.4 as the 7.3. Albeit smaller, but still the same # nonetheless.
I've had trucks in here missing 2 or 3 of their 6 bolts on a 7.3.... hundreds of thousands of miles. Not 1,000 rwhp trucks, but still. Hell mine had 1 missing for the longest time.
It should. The patterns are identical.I think he means if the 6.0/6.4 use the modular pattern then why wouldnt the 4r100 (out of a v10 with the modular pattern) bolt directly up to the 6.4/6.0
Nope. Thanks
Any update? How well has the 4r been holding up to this point? If there is a new thread that I do not know about I apologize and would like a link. Thanks!
