6.0 airdog 2 on a 7.3
Dustin F2504x4
Winchester Ky
I have a 6.0 powerstroke airdog 2 that I have laying around and was wondering if it will work on a 7.3 powerstroke? Will it work with no issues or do I need to sell it and buy another?
Radioflyer
According to air dog, both the 7.3 pump and the 6.0 pump on the 165gph pump runs at 50-55psi.....that being said it should work. You would just have to adapt the wiring harness and the fittings IIRC to work on the 6.0.
fordfreak4life
*** Airdog, those things are expensive paper weights
Sent from my SCH-R530X using Tapatalk
Radioflyer
If it were me, I would try and sell the ADII I'd run a regulated return. Your truck will be happier in the long run and run better. Stock pump will fuel for pretty decent size injectors and plenty if your running a stock HPOP. A regulated return will remove the fuel bowl and allow for more consistent fuel pressure. Pair that up with a post pump and pre pump fuel filter setup and your golden. I can facilitate all if it if needed. Let me know.
bruce
Middle east
piece of sh1t, I wouldn't run it on either. sell it to a common rail or mechanical guy
