HaysKSFirefighter
Ok, yesterday my pickup ran great, lots of power, no issues. This morning, I fired it up and it was a bit rompy but no problems starting. I took off down the road and had no power. Went on a ten mile drive to work, the thing would barely get out of it's own way. It's knocking and shaking badly, almost as if it's starving for fuel. It's gutless as can be. I changed the fuel filters after work and it's running a bit better but still like crap. I'm thinking my fuel pump crapped out on me. Any other ideas? I didn't get a chance to check fuel pressure tonight, I'm hoping I can in the morning. Any other ideas or things I should check? It doesn't smoke a lick at idle or when I'm giving it heavy throttle trying to get up to speed. No blowby, no codes, boost will still get up to 20psi, just takes a long time, and icp will go up to 2800ish. I'm used to pumps dying in 7.3s where they just quit and leave you stranded, will a dying or dead pump in a 6.0 allow it to run, just barely, but run nonetheless?
