6.0 Motor For Sale
BlueFordExcursion
$5,500 - Located in Bellingham MA - Back up for sale is my entire motor. Super clean, daily driver, smooth power, over-maintained. All work and maintenance done by the same diesel performance shop in eastern Mass. ********** tuning 100% of the time. Daily tune: 600 hp. Full fuel tune: 700hp! Dyno sheet to prove power numbers. Everything is built right, no corners cut ever. My Cummins conversion is almost complete...need to clean out parts. I am keeping the 6.0 wiring harness and FICM.
118K on long block, 40K on heads, 15K on performance parts
Motor:
x-EGR/Oil Cooler replaced
ARP Head Studs
PowerMax Turbo
DieselSite Wicked Wheel 2 for powermax
Swamps 170/50 Injectors
Driven Diesel Regulated Return
DieselSite High Volume HPOP
No Limit Fab hot and cold pipes
AFE high flow air cleaner
AirDog 100
NUC Motorsport remote oil filter
SCT 3015
FICM tuner
New ICP and IPR sensors installed with HPOP install
New standpipes, turbo drain tube, and high pressure oil lines installed with injector install
4" stainless downpipe and mid-pipe wrapped with heat fabric
Stock intercooler
Stock HFCM
Like new stock alternator
Upgraded custom 2 awg battery and alternator wiring
Also available are suspension parts: V-code srings with Icon 2" mini pack, PMF rear 4" blocks with traction bar mounting points and 3/4" ubolts (bars not included), 6 Bilstien shocks, Icon dual front shock brackets, dual pro-comp steering stab brackets with fox shock steering stabs
Take it all for $5,500...my storage unit needs to get cleared out!
