RNally
Had a customer tow a truck in that the engine was replaced in and cab lifted off of. Made sure everything was hooked back up, all fluids full, reprogrammed and FICM, PCM, all that good stuff.
ICP cranking is over 1,000
FICM V is 48
I can get the truck to fire, but it dies after a second. If i gas it, it will continue to run anywhere from 5 to 8 seconds, but then completely dies.
Brand new batteries as well. However, cranking the batteries drop to low 11 V's, when the truck fires and I run it up to around 2,800 RPMS, the ALT is right around 12.2 V
No codes of course. Anyone have any ideas on where to even begin?
FICM V is 48
