6.0 surge please help
snoracerx
Here's the story truck is an 04 icp in rocker cover but from what I've been told it doesn't have the stc fitting because it has a cast hpop cover
Truck randomly surges and idles very erratically I kinda got it on video video isn't great but the best I have right now my 8 year old is the one asking
Truck
Studded
Egr delete
Blue spring mod
4 in turbo back
S&b intake
Turbo cleaned
Newer ficm
New icp
New cam sensor
New ipr
Running the truck stock right nto eliminate any variables
You can see the ipr % for from its normal 20-24% at idle to 40% without me touching the throttle I'm totally lost as to what could cause this also sometimes it will stumble then surge or sometimes just die
I've spent so much money on this truck that it is getting frustrating I just want it fixed once and for all
http://youtu.be/FF4KHSje9Gs
Sent from my iPad using Tapatalk - now Free
Lassie
Tenn River Alabama
Do you have any codes? Could be several things, ICP related, TPS, FICM....really need to check for codes and put a scanner on her to get anywhere.
snoracerx
Guess I forgot to add that no codes it's not the tps if you watch the video the value never changes until I press the pedal
Sent from my iPhone
reilly8282
I have the same problems with my early 05. Feels like a cylinder dropping out then coming back on. I haven't found the fix but I'm in to see what you come up with. Only happens warm. Not stiction. I think you see the ipr open because the PCM is compensating for a dropped cylinder by upping icp. Maybe injector dribbling from a clogged tip or bad injector oring.
Lassie
Tenn River Alabama
I cant see video. Have you measured FICM Volts?
If its a single cylinder issue, you should see on a power balance. Injectors can act like this when starting to fail. Does the surging stop or settle down at higher RPM or load?
Also, you probably wont get a contribution fault until you run at cruising speed at full operating temp. This might at least direct you to the right hole.
snoracerx
Injector O-rings are new
It doesn't surge all the time just once in awhile truck is always warmed up when it happens and usually near 80 degrees or above
Ficm voltage goes from 48.5-49 it was new 6k ago
Sent from my iPhone
reilly8282
Same here and running rotella t6. Mine didn't start until after studs and when I first used rotella. Previously used mobil1 5w40. I'm stumped to but glad I didn't buy a new icp and ipr.
snoracerx
Did you do blue spring mod at that time
Sent from my iPhone
reilly8282
I did do the blue spring, just checked pressure yesterday 60lbs only other thing I can think of is doing the bubble test when hot pull the secondary fuel filter and turn the truck over looking for air bubbles. I haven't tried that.
snoracerx
Well I just talked with two different shops and both have suggested the Pigtail for the icp so I'm going to do a wiggle test as soon as I get home I will report back shortly
Sent from my iPhone
snoracerx
Sent from my iPhone
reilly8282
I hope so for you mine did not change, actually disconnecting it idled choppier than before.
snoracerx
Wiggle test showed nothing I'm gonna peal the harness tomorrow and see what I can come up with
Sent from my iPhone
snoracerx
Didn't get a chance to peal the harness open today but I did have to take the truck to town
Yesterday I tried to duplicate the problem by doing the wiggle test got no symptoms. Today when I drove the truck it ran like never before so I'm going to go ahead and replace that pigtail when I get a chance and see what happens.
The pigtail has been replaced before unless they come crimped with but connectors from the factory so I'm hoping it was a bad crimp on the wires and my problem will be solved
Ill report back after I have some more results
Sent from my iPhone
reilly8282
I checked for bubbles while cranking today and got nothing. It's either a small hpo leak on a single injector/rail nipple or and internally failing when hot injector. Hope you figure something out. I may send my injectors in to be gone through and hopefully repaired.
snoracerx
Check the icp harness I believe that's where my problem lies even if it doesn't its 25 bucks vs injector repairs
Sent from my iPhone
reilly8282
Sent from my iPhone
theoretically would that mean the miss, surge would go away and default values with the sensor unplugged? Ive pulled the sensor but never ran it unplugged for a short time.
