MorganY
- Dieselsite's high pressure oil delivery system, full kit. Comes with an ICP sensor and another passenger side valve cover. This is the updated version with the check valves inside.
$950 shipped
- Elite 275cc/100 injectors. Just put new 8 hole nozzles on them two months ago. The bodies might have 20k miles on them at the most since I've gotten them, 6 solenoids are 2 years old, two are relatively new. Note: You need some form of extra high pressure oil, these will not work on a stock oil system.
$2000 shipped anywhere in the 48. No core required.
- Irate diesel T4 up pipe, and CED oil drain. These have the Vibrant 67632 bellows on them. In case of failure, these bellows will not come apart from the inside and tear up your charger.
$450 shipped
- Regulated return, minus the fuel filter mounted plate
$225 shipped
- 4340 Pushrods (they look like this) http://swampsdiesel.com/prestashop/en/0l-push-rods/1132-push-rods.html
$100 shipped
- 125lbs/in valvesprings. I'm pretty sure they are elites
$200 shipped
Everything is ready to ship within one handling day minus the valvesprings.
Pictures available.
$950 shipped
$450 shipped
$225 shipped
$100 shipped
$200 shipped
Pictures available.
