footlong70
Wish I could help you more with testing the vgt but I haven't played with them much. And I don't get that parameter to monitor on my blackmaxx. I know they do fail occasionally or get stuck. If it cycles though freely by hand, fully and springs back by it self then it's not stuck. So unless linkage inside the turbo let go/loose it's probably the solenoid. Is the plug clean and fully pushed in? Do you have access to another solenoid you could swap out and test? I'm sure someone has some tips on testing them.
Everything on the bp sensor/tube side sounds good to go.
