Frank_C
Have a few parts I no longer need due to throwing a single on my truck. Everything is perfectly usable.
The S&B intake has a pretty new filter, however it could use a cleaning. I also bought the intake used, and the previous owner riveted on a sheet over the front vent. This caused the filter minder to go off, so I removed the blockage. Works perfectly fine now, the only "issue" is you can see where it was riveted.
The CFM+ elbow does not include the adapter plate for 6.4's. It does have 1 port tapped in it which I was using for boost control with my wastegate.
The 4" downpipe is mild steel, and does have a wastegate flange welded on it from Elite's wastegate kit.
S&B Intake - $200
CFM+ Elbow wtih 1 Port - $100
4" Downpipe with Wastegate Flange - $150
All prices exclude shipping. (From FL)
S&B Intake - $200
