wiseguy
for sale is used 6.4 short block came out of running driving truck. truck had approximately 130k on it. removed from driving f450 I personally checked truck over when cam in ran perfect no unusual noises. Reason for removal is hg was blown pressure in cooling system oil looked good. pulled it apart rockers were worn bridge plates are bad valve guides were worn timing cover did not leak but is cavitated beyond what I would run. Relative compression only showed 1 % variation engine will include cam crank rods pistons upper and lower oil pan oil cooler and timing cover. Used 6.4 blocks are hard to find I will ship on your dime has forklift to load. My intention was to hone cly install hd pistons new lifters bearing and seals, timing cover and oil cooler. HEADS ARE GONE I rebuilt them and used them for another project. Marital problems force sale looking for 2500 shipped lower 48 or credit card ok.
