CockDiesel
- Joined
- Feb 3, 2016
- Messages
- 5
- Reaction score
- 0
Hi all,
I have a 2008 6.4 L powerstroke , I have egr ****** CCV mod, volant cold air, 310 ******* tune, no head studs yet and 71mm and 58mm turbos that I just put in and it still ran like crap ( low power, lot of black smoke and high egt). I changed the exhaust back pressure sensor and map sensor and had no luck changing the issue . It has 2 codes under check engine, P2563 (boost control position sensor ) but my actuator is running fine and P2263 (boost pressure not detected) but I have no leaks and sensors were replaced.
I just unplugged my EBP sensor today and it ran the best it ever has being unplugged. Lower egt's boosting to 40+. My main questions are should I be worried about the codes? And having my EBP unplugged ? And will it hurt my truck leaving it unplugged.
