6.7 update now a service advance track warning
TXGLASSMAN
Keller Texas
I did the up date on my mini max and after loading it I started the truck and now have a service advance track warning and my traction control won't turn off or on. Could this be in the tuning or do I have an issue the dealer needs to look at?
SAK
Victoria, Texas
I have 6.7.18 and don't have that problem, I see the latest one is 6.7.19, did you try to reload the tune?
Sent from my MB860 using Tapatalk
TXGLASSMAN
Keller Texas
I adjusted the tire size
I think if I take he truck back to stock ad re down load the update to the SD card and then re load the H&S it should clear it hopefully
SAK
Victoria, Texas
What size did you adjust the tires to? Sean said he had some problems when he adjusted his when the ability to go over 35's(or close to) was available.
