I'll send this link to my friend matt. He has MPD 66/88 compounds , dual fuelers, and 60s. Truck is a blast.
As Josh said, Matt's truck (blcksmk08) is probably one of the more ridiculous compound trucks on here that is zf6 equipped. His truck is setup perfectly for daily driving or balls out street tomfoolery.
Thanks guys!
2008 F250 ECSB
66/88 Maryland Performance compound setup (old style)
Elite Dual Fuelers
Swamps 60% Injectors
Beans Diesel Sump
Fuelab Velocity 200 pump
Elite fuel bowl delete and regulated return
Fully Balanced rotating assembly
Bored .020" over with delipped coated pistons
South Bend 3850 Slipper style clutch (stock trans)
RCD Stage 1 valve springs
GoGo Diesel Stage 2 ported intake
GoGo Diesel Stage 2 pushrods
Stock heads checked, decked, and clearanced for pushrods
ARP head studs
MPD manifolds and up-pipes
MPD CCV and driver side valve cover with CCVs
Dirty Diesel Customz coolant tank
Outside Appearance
BDS 2.5" leveling kit with PMF 4 rear block
Cervini Hood
20x10 BMF Stealth Novakanes (soon 22x10.5 Death Metal Novakanes)
Hankook Dynapro ATMs
Custom 5" Dual over the axle exhaust with Carbon Fiber silver tips
Amp Steps
Smoked out everything
LED everything
PMF brake lines (best investment ever)
Interior not important just some shinny Isspro gauges, add on loud things, make your back sweat seats, and black carpet
Soon to come
OUO bolt on traction bars
Headlights by JD
Trans Brace
Then hopefully Im done lol
As for drivability I love the way its setup right now even though my friends don't seem to think so. Its tuned by Josh at RCD and he has the fuel turned down way low cause I cant stand smoke at idle and off the line. I like the appearance of a turtle off the line to get people off track then when the turbos spool and it starts fueling its end of story. But when i had it tuned full fuel the turbos spooled decent with a lot of smoke. Definitely no stockers. It gets hot quick. But I handle it very well. Never seen over 1150 egt dailying it. But wot Ive seen 1600 the hottest. Cruising temps stay around 700-850. It cleans up every bit of the fuel at 73psi. Back pressure has pegged 100psi when the gate was stuck closed. But with it adjusted properly i usually see around 65-80psi. Cant really think of much more to say about it :shrug:
Ill get pics when the powder coat is done and the new rims are on.
