HobbyStock62
started out wanting a powermax and 155s, now were here...
what i would be using this set up for is a daily driver, weekend tow pig (12,000lbs, max maybe 20,000lbs on the high side) and the occasional run down the quarter mile. i dont pull very long distances, maybe 60-80 miles any given week, possibility for a couple of 300 mile trips next summer.
this fall, when i dont need my truck to pull, i will be doing the supporting mods build. head studs, heads, complete fuel system, and egr delete. i will go easy on the trans and make that last a year or so, then build that.
the turbos that i would want to use (but open to hear other options) is a FMW 62 and a s475. i can get both turbos for a little over 2000 shipped.
that is about as far is i can get without asking a whole lot of stupid questions and getting responses for dummys. here go said questions...
1. What else will be needed to make a compound set up work? I know mounts, IC piping, a waste gate of some sorts, up pipes, but what else and what should i get for gate and up pipes? when i have the cab off of my truck in the fall i can figure out where to mount the turbos (where the stock one is and the other where the right battery would be) and make mounts, unless there are more to these mounts that i think? if it is just a mount to bolt the turbo to the engine, than i can make those no problem, but i have never dealt with this, so i dont know what else would be on a mount.
2. I will only do this if i can keep AC. is this doable, or should i stop now?
3. what boost will the stock intercooler hold?
4. Price, price, price. what should i expect for to spend of everything from question 1 and the rest of the parts that I do not know.
sorry if these sound stupid, but i just dont know the answers to these and cant find them on the internet.
any help is appreciated...
Thanks, John
Thanks, John
