6637 or aftermarket cold air
Magnum PD
VA
If you got the spray oil on the filter kind,
Take it out of the truck, find some gasoline, soak the K&N throughly with it, make sure it's in a open place and throw a match on it. Watch it burn and rest easy knowing you saved your engine from getting dusted.
Kae006
Jody @ DP recommended I stick with the stock intake. His exact words were "Keep the stock air box if it is not damaged since it flows more than the 6637". What is everyone else's opinion on that?
ToMang07
Mainah!
6637 and be done with it. Any other advice is meant to sell you something. No sense reinventing the wheel.
ToMang07
Mainah!
"it flows more than the 6637". What is everyone else's opinion on that?
more then likely he was looking at cfm but everyone has made more power with a 6637 then a stock box.. like i have said a million times, golfer at swamps has made over 800 fwhp with a donaldson filter... stock airbox makes about half that i think!
Arisley
Arlington, Texas
Prior to hearing about the 6637, I was using zip ties on my stock air box to keep it sealed.
With stock or near stock, it is fine. When you start using a lot of fuel running a turbo that sucks a lot of air, the stock box will not keep up.
but it doesn't pull the minder in the stock box so its fine.......😒
gnxtc2
Bergen County, NJ USA
Where are guys buying an authentic Donaldson filter from? What is the correct part number?
When I was running a K&N filter, the silicon numbers in my oil samples came back good.
I'm running an open AFE filter currently.
Billy T.
[email protected]
Arisley
Arlington, Texas
Go to O'Reilly's as for a Wix 46637. When you take it out of the box, the filter will have a little sticker on it that says Donaldson 6637.
ToMang07
Mainah!
Interesting. I'll have to check that out. Only place (locally) that carries a 6637 around here is NAPA, and they want something like $90 for a non-donaldson one.
psduser1
on the road
Or call dale at tymar, afaik, he'll still sell you a donaldson. Can't remember for sure it was less than $50, shipped.
