7.3 build questions
David N
Eastern NC
You shouldn't have taken the heads off. If you just bought another running motor, you should have just taken one head bolt out, and then put a stud back in. One at a time. Thats the best way to do a 7.3 thats never had the heads off.
Cody
NW OHIO
It already had the heads off the guy before me pulled em regardless of that what's the best way to clean this pig up
DocBar
Akron, Ohio
No I'm only putting head studs in this block
Are you buying a rebuild kit for later? Why not just do it all right now, while it's on a stand? I understand you're on a budget but doing it once is always cheaper than doing it twice. Since the heads are already off, it makes sense, to me anyway, to go ahead and do the whole thing. Just my 2 cents.
