Hello.. Having problems with my psd. Driving on the interstate truck would loose power then suddenly regain it. Came to a stop and it shut down but started right up. Later that day returning home from work it shut down coming to a stop and never restarted since. By the symptoms and without a scanner first thing I did was replace the CPS (did oil change and fuel filter at same time) which was purchased from the ford dealer, didn't fix problem. At that point I ordered the AE ford enhanced scan tool. Scanned it and codes found were for ICP and EBP sensors.. codes P1211 and P0470. Pulled plug off ICP and it was wet with oil. Drained some fuel from filter bowl and checked that it filled back up. My question is would either one of these sensors cause it to not start?
ICP with ignition on
.19 volts
14.84 duty cycle
ICP while cranking
40.70 psi
.29 volts
64.84 duty cycle
Any ideas or other tests I should run with the scanner? I need this back on the road!
Thanks
Sent from my SM-G925T using Tapatalk
.19 volts
14.84 duty cycle
ICP while cranking
40.70 psi
.29 volts
64.84 duty cycle
Thanks
