7.3 Died and Won't Restart
Black 02
Woodland, WA
Yeah, the drips were happening even before it was running though. The drips were about every 15-20 minutes when it wasn't running. When it was running, it was about every 5 seconds.
I will clean it though and see what happens.
At least try to find it before it springs a big leak. Lpo leak will shut you down in a few minutes. Hpo leak will **** you down in seconds. Id find the source and fix it before it gets bad.. i highly doubt it is a rear main... clean clean clean. If it is that bad you will see the leak when looking on top of the motor while running. It will either be from the hpop area, hpo rail fittings or lpo turbo area. Or oil plugs on the backs of the heads.
