7.3 Engine R&R With 6 Speed
Gary
South Lyon Mi
Will the engine come out with the trans still in? For some reason I think I remember it won't. I've done plenty of 4R100's but never a 6 speed.
DEEZUZ
NO PUKESTERS
NWI
Das ZF is like 2x the size of the 4r...its like 2 inches away from the trans tunnel... You'd have to have one hell of a tilt going on to get it out together... Just separate it, leave the trans in the truck
Gary
South Lyon Mi
So the engine will come out with the trans still in the truck?
I was thinking the trans had to come out before the engine could come out
DEEZUZ
NO PUKESTERS
NWI
I support the trans with ratchet straps to the chassis. But ideally the trans would drop out, then you take engine out.
Strokersace
Towanda, KS
Like CTC, I always leave the trans in when pulling an engine. Support the front with a ratchet strap. Trans only comes out when it needs to!
hucorey
Defiance, Ohio
Ya, definitely do not pull the engine and trans together. That ZF is one heavy sum beech for a pickup transmission anyway.
Sent from my Pixel 4 XL using Tapatalk
